Shear Wall Line Offset
I have a building that has a lower roof that intersects a main building in between an upper and lower floor diaphragm. I am carrying that roof shear down through a short shear wall to the lower floor diaphragm. I have included a pdf to help visualize. These short shear walls (E.1 and E.2) line up in between two shear wall lines (E and F) of the lower floor diaphragm. I have shear walls below along E.1 and E.2.
My question is, do I have to fix the main floor diaphragm at E.1 and E.2 in order to create a reaction for the shear walls along E.1 and E.2, or can I consider some sort of load sharing between E & F walls by transferring E.1 and E.2 through the floor diaphragm? How far offset can I assume that shear walls act along the same braced wall line?
RE: Shear Wall Line Offset
