ETABS TRUSS 3D ANALYSIS
Hi, I need advice in modeling 3d truss in etabs. I was confused on which part of the truss should I release. When I released the trusses and run in full 3d, the members' displacement is very large and it's not realistic. Also, the columns are failing in large amounts as well. When I tried to set the top chord and bottom chord as continuous(no release), the columns produce realistic p-m ratios. What could be the right thing to do in this situation? Thank you. :)
RE: ETABS TRUSS 3D ANALYSIS
Please release only M2 and M3 at both starting and ending nodes of the truss elements.
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
