Welder Qualification of Branch Weld
Dear all,
Im kinda stuck at welder qualification of branch welds. We have a nipoflange which connects to pipe's surface directly (with bevel and full penetration) but since it is not a butt weld and has nearly 20mm thickness I couldnt find anything related to this in ASME SecIX. Is this treatable as fillet weld or should I qualify a welder according to required diameter and thickness limits.
Thanks.
Thanks.
RE: Welder Qualification of Branch Weld
Birken
