navigate in NX
navigate in NX
navigate in NX
Is there away to navigate through an assembly, into housing walking rotating looking at the inside, generating a video giving a virtual preview?
sorry new in NX
regards
Erwin
RE: navigate in NX
If you are very skilled in using the Navigate function found under View- Operation, you can capture a video of the fly-through.
( difficult...)
If you have the correct license level of the Vis - Viewer, it's easier to do the fly-through.
I don't think the fly mode exist in the lowest level license, - ?
Another option, also quite difficult to set up as desired , is the View- options- navigate Options... where you can define "keyframes" in between which NX will interpolate the movement, or use a "trajectory curve" along which the camera will move.
This fly-through can be rendered into a video or screen dumped into a video.
The keyframes / trajectory curve method can be step by step edited into the desired fly path.
Tomas
RE: navigate in NX
thank you guys
I have looked at navigate not clear howto -
sorry new in NX
regards
Erwin
