Beam column joint rotation
Hi all, some programs give the amount of joint rotation per load case, I wonder what is the use of this? for both RC structure and Steel structure.
RE: Beam column joint rotation
Rotations and deflections give a clear picture of how the structure is deforming under load.
BA
If you design a bridge bearing pad, you may want to know the joint rotation at the location of bearing pad.
Moment curvature analysis,reinforced concrete column design and prestressed concrete pile design at www.structurexpress.com
