Customizing Hole Notes
We are in the process of moving from NX to CREO 2.0, so I'm sure I will have many questions.
My question today concerns hole notes. I went through the help files and knowledge base, and I have the notes working for threaded holes. What I am wondering is if it is possible to get them to work with non-threaded holes?
Using NX7.5 & Creo 2
RE: Customizing Hole Notes
Now when you go to your drawing and show the notes, each hole note will be auto generated.
If you find a way to auto generate a note for a simple hole be sure to share!
You can also play with the note format itself. Theer is a PTC TPI/TAN that explains how.
Ben Loosli
