Sample Plot Styles Required
We have installed autocad 2002. I am having a hard time understanding plot styles, page set up, etc.
I would appreciate some help in setting this up.
can you provide me with help.The 2002 user guide is difficult to follow.We are on a network.thanks
RE: Sample Plot Styles Required
Make sure the "printer support" path is pointing to the directory which will hold all your pen settings.
This would be under the "options" box.
SECOND
Open an existing file and righ click the layout tab, which would be the "paper space tab". Go to the page setup option.
THIRD
The dialog box should look like the plot box. Click on the 1st tab and choose your printer and choose your "pen table".
FOUR
Click on the the 2nd tab and choose your scale; your window/ extents; and any other normal settings from previous versions of AutoCAD ... that you are acustom too.
FIVE
Your done!
Click ok/ apply!
Now the next time you open this file you should be able to print the file with the preset settings already there ....
I hope this helps!
Rich@LG
