GD&T tolerancing in NX
Hi --
Can anyone here explain me what´s the difference is between GD&T and GPS.
I'm jobseekers and I am asked if I have experience in GPS .
My answer is that am used to use geometric tolerance in NX , called GD&T.
Bu I am not sure ,if it is the same as GPS.
lklo
RE: GD&T tolerancing in NX
hi cowski -
thank you for your post .
you are right - gps is a further development of gd&t
in the attached pdf file , it is explained very well and precisely.
lklo
you are right,I´ll take a look there.
Maybee (if I´m Lucky) I will get a job at Siemnes Windpower (Denmark), as consulent from Avaloninnovation.
It´s a hughe Company - they have over the last 3 years migrated from inventor to nx ,and stil not finished.
Siemens Windpower use GPS extensively.
lklo
