Mirror Facet Body NX7.5
I want to mirror a facet body to see what a full studio surface will look like.
Unfortunately I do not have the Shape Studio license.
I can use Mirror Display, which mirrors everything visible. But this is just a quick look and I want something more definitive.
RE: Mirror Facet Body NX7.5
If the Transform option isn't visible under "Edit", use the Command finder and search for "Transform".
( Use "Mirror through a plane" and finally "Copy" , press cancel when done. ( OK will create another copy.) )
Tomas
However, because it's a faceted body, I can't export it to .stp or .x_t .
Any help?
Can you split a faceted body without Shape studio?
Tomas
