Flow Simulation
Flow Simulation
Flow Simulation
Hello All,
Thank you in advance.
I just started using Flow Simulation and I would like to know if there is a way to simulate Air traveling thru a tube and out the other end of a nozzle with a pattern of hole in it. I want to know what the Air will look like, meaning projected on the output end of the tube. For example, if I add different size holes and different angles to them, what would it look like.
I'm sure more info is needed, so please ask and I can explain to send some sketches.
KenG
SolidWorks 2013 Premium
RE: Flow Simulation
What version of solidworks are you using? You have to use lids to tell solidworks where the air should flow. I will try and simulate getting SW to show output pattern but haven't seen any yet.
RE: Flow Simulation
nvm I see 2013 premium.
