PIC Microcontroller Watchdog timer
I am not sure if the topic fits here. Is there any microcontroller forum here??
Any ways i have my PIC16F685 on which i have watchdog enabled and it works fine and resets the pic on time out, but once i enable the GIE or PEIE (that is the interrupt - timer 1 actually) now the watchdog does not resets the pic but the pic goes on running with the timer 1 doing the regular interrupt.
Am i missing something or is this the way it is suppose to happen.
Gokkul
RE: PIC Microcontroller Watchdog timer
Keith Cress
I solved the prob.
You are right so i went deep down onto the disassembly listing and found that "__delay_us(20)" function, which is a function provided by the compiler for delay inserts a CLRWDT in the code
If i change the delay form 20us to 10 or 30 us its does not add the CLRWDT.
But any way found the culprit.
Now the program resets fine.
Gokkul
Keith Cress
Gokkul
Normally I'd say email them with this. They've fixed 3 compiler errors I've found in the past. Usually in less than 24hrs. But since Microjerk bought them to murder them and damage all their competitors I have no idea whether they can fix anything or not. Might be worth at least shooting them an email with all the details.
Keith Cress
