Script to get co-ordinates of specific nodes in ABAQUS
Hi Everyone,
I know this is a basic question, but bear with me please.
I am required to get the co-ordinates of specific nodes on ABAQUS.
I know I can use the tools---> query----> probe values, but this is a rather tedious task for the amount of nodes I need information from.
I know the numbering of the nodes, but just not too sure how to write a script which will save me time in doing so.
If this question has been covered before, I apologise in advance.
Thank You
Thank You
RE: Script to get co-ordinates of specific nodes in ABAQUS
In order to get the coordinates of specific nodes:
1) Define the node set
2) Field output request->Domain: Set-> Your node set->Volume/Thickness/Coordinates-->COORD
3) Then, if you want to assess the nodal coordinates of your set with a python script, you should use http://www.eng-tips.com/viewthread.cfm?qid=352989t... Coordinates.getSubset(), see Abaqus Scripting User’s Manual.
Ger
Thank you so much for your reply, I understand what exactly I need to do now.
Although, I think the link you submitted may be inactive.
Inap777
Thank you so much, your time taken to answer my question is much appreciated.
For point 3, did you type the correct link or has it been lost?
