Slip Critical Connections in Industrial Pipe Racks
What are the pros and cons of specifying slip critical connections for bracings in industrial pipe racks exposed to weather(+90F summers to -20F winters) not a seismic zone, with high winds?
RE: Slip Critical Connections in Industrial Pipe Racks
Michael.
"Science adjusts its views based on what's observed. Faith is the denial of observation so that belief can be preserved." ~ Tim Minchin
- Code requires Slip Critical Connections in certain cases, such as in significant load reversals or wind loads, etc. Can that be interpreted to apply to a pipe rack exposed to weather?
- Being out in the open, how much corrosion should one expect to the faying surfaces?
- Given the above, it is practically advisable to have SC connections for such a structure
I see no reason to have SC connections in such a case....please share your take on this.
