Sheet in b\w like preview
hello! where I'm wrong?
I have a few questions and upload some file to better explain
https://www.dropbox.com/s/55ey6izcmqwzhjg/thicknes...
https://www.dropbox.com/s/5e31fr1lxsx2eu8/thicknes...
https://www.dropbox.com/s/7hd3gduhy1alyus/afranx.c...
How can I see all the lines in b\w the sheet instead of seeing the color of the layer?
Why in LayerManager the box printstyle is not always accessible?
Can I put LineColor for example: Red and Printstyle: color_7 (or the correct value to display black)?
What settings need to see the colored lines without thickness in model space and lines in black & white but with the thickness of the sheet? I would like the sheet is equal to the print preview. Currently I see in the sheet the lines thickness only if I set the layer manager linewheight.
Why the print preview is different from print to pdf? The pdf is correct, you can see the thickness of the lines correctly, but not the lineeStyle.
tnx
