Overhead welding
Overhead welding
In the distant past, I read and recall using a fifty percent reduction for overhead welding.
Is this reduction used today? And if so where can I find it written? Thank you in advance.
RE: Overhead welding
Never mind the pain and burns ... 8<)
Add also the time to get scaffolding, your fire watch, the equipment, etc into position. If you can avoid the overhead weld, do it.
ZCP
www.phoenix-engineer.com
