Session file - Automatically respond to popup warning
Say I have a session file that looks like this:
CODE --> PCL
STRING asm_create_grid_xyz_created_ids[VIRTUAL]
asm_const_grid_xyz( "1", "[0 0 0]", "Coord 0", asm_create_grid_xyz_created_ids )
asm_const_grid_xyz( "2", "[0 0 0]", "Coord 0", asm_create_grid_xyz_created_ids )
I'm going to get a message,
CODE --> PCL
$# Question in application SGM by application Geometry
$#     Point 4702140 already exists at the specified location to create the next Point. Do you wish to create a duplicate Point?
to which I'd like to answer Yes. Is there a way to do that in the session file? Or to suppress the warning altogether? I know that if I run from a command line, I can use something like
patran -sfp test.ses -ans yes
But I'm looking for a way to do this through the normal Patran interface.
Thanks in advance!
