Heat Recovery System-Absorption chiller with economizer
Hi my name is HEctor Rivera
I am a student engineer from Puerto Rico. My first project on the industry is to design a heat recovery system to produce chilled water. Also, to reduce energy consumption.
We have a thermal oxidizer an the gases pases through a pipe were are cooled injecting water. The heat wanted is on this pipe. The steam has a flux that Varies between 2,000 to 12,000 cfm.Temperature values Range between 450°F to 600°F and are corrosive gases.
We are thinking to use a absorption chiller with an economizer. If someone has experience with this equipment please send me some information. Thanks
RE: Heat Recovery System-Absorption chiller with economizer
B&W, Cleveland, Ohio
