Tieback Anchors at Water Table
We have a project with some tieback anchors very close to water table (a little above and a little below) where they come through the wall. Obviously they then are anchored down in the soils below water table. We have done a couple of these and the contractor always cases the holes. On this project the contractor is adamant he doesn't need to case the holes and plans to 'open hole' the anchors.
This seem to me like it will not work. What are others experiences with this?
RE: Tieback Anchors at Water Table
Mike Lambert
Better watch/document to see how much material is being removed so you know how much compaction grouting or other remeadiation to plan for when the ground outside the wall starts to move.
Mike Lambert
dcarr82775,
There is no way to know for sure if you can or can not work through open holes until the contractor gives it a try. Even if the drawings do not allow it, if he demonstrates in the field that it can be done, I don´t see why he should have any restriction for doing the job his own way, as long as the structural capacity and integrity of each anchor is succesfully tested.
