Using one 12V power supply to provide +/-5 Volts
I'm using a 12 volt battery to power a non-inverting amplifier and I need to use the battery as a +/-5 volt power supply. How do I go about doing this?
RE: Using one 12V power supply to provide +/-5 Volts
How much current do U need, tolerances, ripple ?
<nbucska@pcperipherals.com>
DC to DC converters.
Suggestion: Create the zero dc neutral (0VDC) at 6V. Then, finetune the voltage to plus minus 5V by potentiometers or trimmers.
If Memory serves me correct, Dallas Semiconductor, made a simple 8 pin dip that did the +/- from one source thing, the current is not a lot, but it did do the job for what I needed....
G.
