What does am Instrument Engineer's Job involves
Hello, I am looking for some info on what does am Instrument Engineer's Job involves?
Just few brief lines on daily job, what are they expected to know, what career path is this going to lead into etc.
I am looking into a job for Trainee Instrument Engineer for Weatherford.
RE: What does am Instrument Engineer's Job involves
http://www.controlandinstrumentation.com/
http://www.myoilandgascareer.com/role/instument-en...
Good think the job doesn't entail using a search engine to find a definition of a job description.
in an operating environment, it is a combination of factors, factors that you cannot really learn in the class room, though the class certificate may help you gain entry,
if you are a quick learner with basic mechanical, electrical,& plumbing knowledge give the job a go,
ask to talk with the maintenence shop, you'll find out real quick where you and how you'll fit in, or if you even want to go that route
if you are a school boy predominantly, you'll have to go the software/computer route i.e. the current push in the market, unfortunately most of that work is outsourced to the lowest cost market and very difficult to land a starting slot
"Will work for (the memory of) salami"
He had to have some smarts if he knew the front from the back of a 'screwdriver' . . , :>)
Dan
http://www.isa.org/Content/NavigationMenu/Products...
Regards, Mike L.
