Learning CNC software
hello,
is it difficult to learn a CNC program?
i have a still active catia v6 (student) version, but not for long anymore (couple of months, half a year or maybe a little more).
i have some training materials for milling, but i don't have a machine at my disposal.
would that be sufficient to learn at least the basics of milling? would transitioing from that program to a real machine be linear (just plug in the correct postproc and we have a go)?
where do you get the optimal cutting speeds (rotation, velocity of movement) for different cutting tools? SANDVIK is a renouned tool company around here.
and anymore tips that you guys could give me?
except go through the tutorials, read the help and then design different parts and try to make a milling program for them?
i am located in central europe and am currently unemployed due to a troublesome economy.
mech engineer just graduated (design, mechanics field of ME though, not production technology)
but i still have catv6 and solidworks student @my disposal.
best regards
best regards
RE: Learning CNC software
Proud Member of the Reality-Based Community..
To the Toolmaker, your nice little cartoon drawing of your glass looks cool, but your solid model sucks. Do you want me to fix it, or are you going to take all week to get it back to me so I can get some work done?
However, most companies have software that almost does all the work for them and there is NO need to actually write the code anymore by hand.
Speeds/feeds can be found in a book BUT nothing is 100% perfect and there are many other factors involved.
Learning CNC programming is simple.. Being a skilled machinist requires experience and plenty of it to be truly skilled at it.
If this is a career path that you would like to follow, you should gain experience in machining, first and foremost. You could offer yourself to a company as an apprentice or intern. Practical experience is the best teacher, with books and reference material to be used as a seasoning to the meal, not the meal itself.
If this is merely a quick solution to your unemployment, you might consider other things.
i am hoping that at least software knowledge (and theory - different strategies etc) will help me to get a foot through the door.
4 minutes of CNC machining "crashes follow"
http://www.youtube.com/watch?v=d4zzFiTCzg4
Software For Metalworking
http://closetolerancesoftware.com
