how to assign mass in ugnx 7.5
I am using some custom gear box (step file) in my assy. vender is not given the material details but he gave the total weight of gear box,
Now I have to add that weight to gear box.
In previous cases we are adding density to find the weight of component in this case I don’t have density I have weight only
Please help me how to add weight directly.
lohith
lohith
RE: how to assign mass in ugnx 7.5
Analysis -> Advanced Mass Properties -> Advanced Weight Management...
...and 'assert' your various mass properties data.
However, if you don't have a license for an Advanced Assemblies module, then you will have to divide the given weight by the volume of the part as measured using...
Analysis -> Measure Bodies...
...to get the needed mass density which you then assign to the model by going to...
Edit -> Feature -> Solid Density...
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
