Torque wrench Calibration: Required date as per which code.??
Howdy.
Working with B31.3 piping as well as fired and unfired boilers/vessels/exchangers on a SAGD site in N. Alberta
Can someone please direct me to where in the ASME codes is the stated interval for calibration.? I have always considered the maximum time between claibrations is 1 or sooner depending up service...just like to know where that is stated.
Thank you,
Stk
Thank you,
Stk
RE: Torque wrench Calibration: Required date as per which code.??
Plymouth Tube
Im fully aware and have always used a yearly frequency unless a TQ wrench has become damaged or is suspected to be out of calibration. I was simply curious if this was an item that might be required by either Sect V, B31 series or API for that matter.
Stk
cHEERS,
sTK
