Blower Design - When is an Outside Air Connection Recommended?
I often get quotes for positive displacement blower packages for jobs of mine. In every quote is an adder for an outside air connection. This is for the blower inlet. When is this needed? I can't seem to find anything in the vendor literature. When would you not want it?
Thank-you.
Thank-you.
RE: Blower Design - When is an Outside Air Connection Recommended?
The air that goes through the blower has to come from somewhere. Where do YOU want it to come from? Consider whether or not people will be able to open or close the doors to the room where the blower is located, if it's running. I used to go into a pulp mill where the entrance to one maintenance shop was through the intake plenum for a bunch of ventilation fans. Some days, you could hardly open the door, and if you weren't careful, it would slam shut on you or your appendages if you let go of it.
Engineers who work on HVAC systems balance the typical building intake air and exhaust air so that the typical building is not over or under pressurized. However, there are applications such as clean rooms where I believe the buildings are slightly pressurized to avoid entrance of contaminants.
Building air is "conditioned". That means the air is cooled or heated, or dehumidified. You would be wasting the funds that you spent to condition the air if the air went into the blower.
There are also noise considerations as well. There will be less noise in the building with an outside air intake.
