Stainless Steel
Stainless Steel
Dear Sirs,
I have a doubt because When welding Pipe Stainless Steel 304L use the filler rod 308-L.
But in this case used filler rod 316-L, what happen in the future Their Consequences.
Please let me know its Consequences metallurgy ...
Hope to have news as soon as possible.
Thank you in advance.
Kind regards
Aws 2004
Kind regards
Aws 2004
RE: Stainless Steel
RE: Stainless Steel
In this case the metallurgical consequences depend on the certain service environment. If for example it is for a carburizing environment that may cause metal dusting of SS 316 at high pressures and high temperatures (please have a look at this link: http://www.weldinguide.com/gdanastasiadis/viewtopi...) then of course you shall verify the construction in metallurgical point of view
regards
wegm
