40MPa column on 25MPa Base
It is quite normal to use a lower grade/class concrete in foundations, such as 25MPa. But for columns often higher strength concrete is used such as 40MPa.
My question is, if you have a 40MPa column supported on a 25MPa spread footing, will it be okay.
According to BS 8110 you can use 0.67 of your concrete strength in direct bearing, so I would reason that as long as your can carry the full column load on the bearing area multiplied by 67% of the concrete strength you are fine.
Any thoughts?
Any thoughts?
RE: 40MPa column on 25MPa Base
