Design Procedure
Design Procedure
Good day Mates,
I am requested to prepare a Design Procedure. It would be deeply appreciated if someone gave me a hand. My main questions are:
- Where to refer?
- What are the main criteria’s that should be taken into account?
Many thanks in advance.
Ulvi.
- Where to refer?
Ulvi.
RE: Design Procedure
http://www.nceng.com.au/
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning."
I need procedure for design of steel structures
Let me emphasize that we normally use metric system and our job occupation is design of steel structure - lifting devices/frames, vessel modification and dozens of another areas. From the other hand designs has being done as per DNV , BS , EN and etc. standards.
1. observe geometry of beam to be desinged
2. figure out loads on beam
3. calculate moment and shear
4. select beam big enough to resist loads.
5. etc.
Not sure what your really looking to do
Let me ask you some things-
1)What steps do you go through when you design anything?
2)What codes and standards do you use in your jurisdiction?
3)Who are your clients and what are their requirements/ design constraints?
4)Do you have standard contracts/agreements or procedures for writing them?
If you can answer any of these then you already answered most of your question. If you can't answer them then why are you setting up a paperwork which reflects how design work should be followed? The truth is, most design offices follow different procedures and every project has different requirements depending on a variety of factors. These factors should be known to anyone doing design work. You would need to supply more detailed information than you have already to get much more of a response out of anyone here beyond what has been given.
______________
MAP
Enough with the mates, guys, and gents.
Well ladies/girls/persons of indiscriminate gender I'd always suggested the loosest possible that satisfy functional requirements.
Of course what you probably mean is something along the lines of what is the process capability of the manufacturing techniques typically used to make your kind of structures or something like that.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
I'm wondering the same thing!
http://www.facilities.uiowa.edu/pdc/designstandard...
Perhaps if you can restate your question with a reasonable level of detail we might finally 'click'.
I would say you got a reply as clear as the question.
Since we are in a structural engineering forum it is reasonable that the question relates to a "structure". A structure (in my world) can be a chair, a bridge, a building or a lot of options in between. If I design a bridge for vehicle load, that is one approach. And the floor designed for machine vibrations, another approach.
You mentioned EN standard, I assume you mean Eurocode and that is 59 standards. I have never designed anything that required all 59 but usually at least 3-6 depending on the material.
I would say "Are you a practicing Engineer" is a fair questing. It is not a matter of you getting stung, rather not understanding the question.
Based on experience, If you ask the question in a way that we can understand than you will get help. Somebody will take the time. But to describe how to design a steel structure is not something you can describe in a few sentences. You can look at the link ztungguy provided, it might help. You can also notice that it is nearly 300 pages.
Perhaps what you need is what I would call a "Design Basis Statement". Basically a document describing to the client how we propose to design the requested structure. I have written a few of those. They usually involve analysis methods, suggested codes and critera for SLS and ULS. Loads and load combinations. They are not neccesarily a lot of pages but enough to make the client able to verify that his requirements are met.
Good Luck
Thomas
You don’t do a good job of explaining what you mean by “Design Procedure.” You say... “Hopefully you understand what I am meaning.” No we don’t. But, you have gotten some suggestions of things which might be included in some sort of a ‘design procedure.’ Do you want a ‘cookbook’ which lays out every step from the first step to the last, including when to pick up your pencil, and all you have to do is plug in the new numbers, each time? It sounds like what you really need is a real and complete engineering education, because that starts to teach you how to approach an engineering design problem, without the need for an exact procedure. Almost every engineering problem is slightly different, so one procedure likely won’t cover them all. You have to learn to think on your feet, and apply your total engineering knowledge, as that knowledge and experience fits the current problem. Your general engineering training, knowledge, experience and judgement should encompass what you need to know, how to approach the problem and what details you need to know to start solving the problem. We have kinda gotten away from this general approach to engineering in the last 15 or 20 years. We seem to need an exact cookbook, exact code section on that exact detail, or a design guide with that exact problem in it, so all we need to do is substitute the new numbers, and that’s not really engineering. Or else, we don’t seem to know what to do; we certainly aren’t teaching people to think like engineers, and apply a little of their knowledge, experience and judgement in solving everyday problems.
A design procedure might be better if it were more general, so as to cover more situations or problems in the design office. But, that also requires that you hire real thinking engineers, not just a bunch of pencil pushers and spreadsheet runners. What design codes apply, what load conditions should apply, what materials should be used. Make check lists for various types of problems and various areas and details which need special attention on those sorts of problems. It seems to me that the crux of the matter is that we need more real thinking engineers, with some experience and judgement, and less dependance on procedures and ever more complex codes. There needs to be more one on one, face to face, mentoring of inexperienced people aspiring to be real engineers. And, work done by the younger engineers and techs. must be monitored and checked by senior engineers. No fancy procedure will take the place of this oversight, more complex and convoluted codes won’t either. There are some things you just shouldn’t be pretending to do if you don’t have the proper experience and/or guidance.
(he was an engineer too BTW)
This is the best recipe/procedure there is:
1) Define the problem
2) determine constraints
3) solve the unknowns
Since we don't have 1 & 2... I guess we are done. In my post I asked for these to be provided. Have I beaten this horse too much? Seriously.
______________
MAP
I appreciate all correspondences and would like underline that questions by focuseng are being taken into consideration almost in every single design.
Most of you know that almost every companies has quality manual in order to manage and success best quality in work process. From the other hand this manual is pointed to put physical work into paperwork due to appropriate standards. My intention is the same. I am a structural engineer. I do design for steel constructions like lifting frames/ beam/containers, offshore platforms, maintenance on vessels, tanks, workshop cranes, walkway arrangements and etc. Now, as you see my job occupation is quite large to create a specific design procedure. From this point of view I am pointing to create a general procedure that could surround my job as an engineer. Let me give you a real scenario. Let’s imagine that there is a new engineer just employed by company and has been demanded to design lifting frame. Normally first he should let daylight in client’s requirements. This is what we call Minimum Design Criteria. If client requested offshore he should refer to DNV 2.7-1 and etc. If client intended this container for multiple use he should go DNV 2.22 or etc. If client intended only for onshore purposes he should go EWS D1.1 or BS and etc. In the next stage he should designate materials. Normally I prefer to run handmade calculation then design, then frame analysis or FEA and etc. Afterward to reduce amount of overdesigned materials I double run calculation with reduced properties of material….
Hopefully you understand me better know. Numerated stages above only small part of my job process and I need to put them into relevant paperwork and convert them into internal design procedure that my company or guys after me can refer to. If any question please don't hesitate.
Ulvi.
Then, on the next half dozen different types of projects you work on, keep a detailed list of every step you take in the solution process, and in the preparation of all of the construction documents. Pay particular attention to details which you know tend to get missed, have caused problems in the past, are less obvious than the wire rope or chain tensions, shear, bending moment and axial load in a member. Maybe in the form of a very orderly check list, so the young engineers don’t miss important steps and parts of the design. Some of the items may need to be filled in and whole thing becomes part of the job file; codes to be followed, special customer requirements, general materials specs., special materials specs., specialty items and their suppliers and part #’s, etc. etc. Have several of your better engineers do the same thing, each will have a slightly different/better take on some items. Combine the best parts of each list, for a final list for a type of project. But, keep them open ended so you can add new items as they come to light. This isn’t something that you do and finalize in a few days, it’s an ongoing process.
It sounds like you are on your way then. If you are looking for examples of other company procedure manual then it may more appropriate to ask outright. However giving out proprietary manuals may not be good form. You may be best served by taking Cont. Ed. coursework on ISO-900xx whatever to really get something like what you are thinking. Like dhengr said, it needs to be flexible and fluid. Manuals can sometimes become the devil if they are too rigid or formulaic. In a former life I was "fortunate" enough to work for a manufacturing company and was charged with documenting the entire manufacturing line of one product. What you are embarking upon is a very personal (to the company you work for) adventure and potentially a full time job in itself depending on how large of a process you have. However in some cases what you have already outlined might be enough. It really is more about your company and its philosophy, organizational structure, historical precedent and future vision and risk management than what me or anyone else can tell you. Now, do what dhengr said and get to work
______________
MAP
Your second post should have been your first post, which was a non-post, which is why everyone was kinda annoyed. The more details you provide the less questions and more responses you will get.
Also, per your second post- I still am a fan of good ol' flow charts for design and analysis methodology. And I am a big fan of standardized checklists for QA/QC.
From the way this is reading it sounds like a lot of this (regarding standards used) would be covered under "General Notes" on your company's drawings, so you could start there and expand it for the manual; perhaps with guidance on how you like things noted.
As to design procedure manuals, I'll have to second the suggestion for the ISO's. Even if you just use them for good starting point and tailor it to want you require, it'll save you a lot of time and hair pulling. I met the guys and girls that were responsible for procedure manuals in my last company and they looked like they had had all the joy of life sucked out of them so don't do it to yourself!
Description of the building, gravity and lateral systems defined.
Building Codes used.
Material Properties.
Lateral approach... Equivalent lateral or Modal Analysis..
What softwares will be used.
Soil Information, footing approach--> conventional or piles. Soil bearing values.
Design Loads - assumed floor loads, seismic mass for exterior walls, assumed equipment mass.
Anyway, you get the idea. You are basically regurgitating the general notes and your design in words.
We usually don't touch too much more on analysis methods other than lateral approach, and software / spreadsheets to be used.
Hope this helps.
