Internal Design Procedure
Good day Mates,
I am requested to prepare a Design Procedure. It would be deeply appreciated if someone gave me a hand. My main questions are:
- Where to refer?
- What are the main criteria’s that should be taken into account?
Many thanks in advance.
Ulvi.
- Where to refer?
Ulvi.
RE: Internal Design Procedure
Please provide some background information: what set of standards is common in your location / country? Is inch or metric system used?
If possible, what industry are you in, are there special areas of interest: sheet metal, plastic molds, etc., etc.
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
That said, I believe having this documentation is a requirement of one of the ISO 9000 series quality cert's. If this is not related to ISO9000, check out their requirements anyway for lots of good information on what they think is required for good quality.
But more to the point, how do you do it now? Just document the steps of the design process you are actually doing. Also there are a lot of expert consultants out there who will to sell you this type of document, both good and bad.
Timelord
