MV Aeriel Bundle cable
Hi!
This is the cable in question: http://okonite.com/okonite-wire-and-cable-product-...
Does anybody know how inductive and capacitive reactance works out on twisted Aeriel bundle cables over open wire distribution? System voltage is in the 15kv range, portions of the span will use with this type cable.
Thanks!
RE: MV Aeriel Bundle cable
Inductive reactance will be lower, capacitive higher. It's just a geometry problem, once you know the insulation properties that is. Contact Okonite, they ought to be able to work up the circuit parameters for you.
I did not find the cable impedance data in Okonite documents.
But I found something in Kerite documents:
http://www.kerite.com/catalog/
impedance data.
