Variable speed DC Motors
I have a Woods VFD for a 2 HP DC motor:
Model J200
Ultracon SCR control for 2HP motors
Power supply: 230V, 1 ph, 50/60 Hz
FLA: Input AC RMS 19, Output DC Avg. 11.2
Field: 200V, Armature: 185V
This drive has an RPM indicator but no Tachometer probe.
Question #1: How does it read the RPM?
Question #2: I would like to use this VFD with a 1 HP DC motor (compatible with the VFD). Can this be done? How?
Question #3: If I want to vary the RPM with reasonable accuracy, can I use a 1 HP 180V permanent magnet DC motor or should I use a 1 HP 200V field, 180V Arm. DC motor?
Since I'm not very experienced in DC motors, any info would be much appreciated.
Spiderman
Model J200
Spiderman
RE: Variable speed DC Motors
You should be able to run a 1 hp PM dc motor with the drive...assuming that it does not have any protective features such as field loss. Just connect the armature output of the drive to the armature terminals of the motor.
I would suggest that you recalibrate the current limit of the drive for 150% of the 1 hp dc motor nameplate armature amps...
I would further suggest that you provide a proper overload relay for the 1 hp motor.
