Show part's CSYS in assembly
I assembled two parts and I would like to constrain them using their CSYSs. is that possible?
I'm using NX7.5
I'm using NX7.5
RE: Show part's CSYS in assembly
in your assembly need to set the reference set of your components to entire part. That will show your Csys for the component.
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.2 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
but what you can do is, in the assembly change the reference set of the components to entire part
then when you are done constraining change it back to model (or what ref set you are using)
your methode does work but I still can't select any element of the datum CSYS to costain the other parts to it.
is it allowed to constrain to datum CSYS in NX7.5?
Should be no problem to constrain to Csys.
You should check a few settings:
Are the layers where your Csys is located selectable?
Did you check if you don't have any type selection filters active?
Is your selection scope set to entire assembly?
Mechanical Engineer
NX8.5.2 / TC9.1.2
thank you very much it does work now!!
