Read out Volume and Mass after Scaling
Hi
I'm working with NX 7.5 and was just scaling an engine block uniformly by a factor of 0.85.
After scaling I wasn't able to read out the volumen and mass,because it's just showing me 0.0m^3 all the time. I tried to export it as parasolid but then had the same problem.
Do anybody have a solution for that?
Thanks!
yanyanh
RE: Read out Volume and Mass after Scaling
When you get a result of 0 volume, there is something wrong with your model. Run Examine Geometry on your part, focus on the body and face checks.
www.nxjournaling.com
