Machining Properties, Brass
We need to mill and turn brass fittings using Naval Brass (C46400). Our old fittings were leaded brass (C36000). Primary operations are shaping a 2.5" hex nut and turning a 1" NPT thread. Will machining properties be similar between the two brasses?
RE: Machining Properties, Brass
I would recommend consulting Machinery's Handbook or ASM HANDBOOK Volume 16 Machining for more specific information regarding tool geometries, speeds, feeds, etc.
