Buying a Radial Inflow Microturbine
would someone know where could one purchase a radial inflow microturbine of diameter 1 - 2 cm
All I need is a contact web address or similar of the manufacturer or seller.
Many thanks
RE: Buying a Radial Inflow Microturbine
There are 25 model airplane turbine builders listed here: That web design stinks! - but if you can navigate the thing, it is a list of all sizes in the two main styles of gas turbines: radial flow and axial flow.
http://www.waoline.com/detente/hobby/hobbyturbines...
Thanks, I will browse through those and hopefully find a small sized one.
