Recommended torque values for rubber lined Piping?
Does anyone have a recommended torque values for rubber lined Piping? The lining is neoprene on regular CS pipng.The actual rubber lining extend over the flat face gasket area so no gaskets are required.
RE: Recommended torque values for rubber lined Piping?
oloweider,
You should ONLY take the advice of the Vendor providing your Neoprene Liner! Doing anything else could void your warranty.
prognosis: Lead or Lag
