Datum holes and frame of reference
I have a question about using holes as datums and how a frame of reference is defined (see attachment).
It is my understanding that holes can be used as datums even if they aren't aligned along the same line as shown in the orientation labeled "1" in my drawing (for clarification, Datum A would be the surface of the plate, Datum B would be defined with perpendicularity in A and datum C would be defined with position in A and B). A few of my colleagues believe it is not correct to do this and that the orientation shown in "2" is the only correct interpretation. Which one is correct?
RE: Datum holes and frame of reference
http://www.tec-ease.com/gdt-tips-view.php?q=243
Just try to ignore the fact that the drawing does not fully define true position of hole C relative to hole B
I have an assembly composed of several welded plates and I would like to use the plate I used in my example (see previous attachment) as the base. At the child part level, I can attach the tolerance to the hole dimensions and use these to define a datum. At the assembly level, there is some disagreement in my office on the correct way to setup the datums. Here are the three possible arrangements:
1. At the assembly level, the surface of the plate defines datum A and the datums B and C are defined by the holes. Since this is on the assembly level, reference dimensions are used on the holes and the same tolerances used in the original child part are attached to the reference dimension. The datums are then oriented relative to each other with basic dimensions.
2. At the assembly level, the surface of the plate defines datum A and the datums B and C are defined by the holes. All of the information that was on the child part for defining the holes/tolerances/datums is copied to the assembly level.
3. At the assembly level, the surface of the plate defines datum A and the datums B and C are defined by the holes. Datum tags are added to the holes and basic dimensions are added to orient the holes to each other without tolerances.
Personally I think #1 is the correct method, but it seems like adding redundant information could cause issues down the road. What is the best method for setting up the datums on the assembly level?
John Acosta, GDTP S-0731
Engineering Technician
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
