SE custom templates gone?
We just reinstalled SE on my new CPU. I copied all my custom templates over to the TEMPLATES directory (i.e. my companies title block, etc). However, the only templates that show when I start up SE are standard templates that come with the program. Any idea on how to get these to show?
thanks
thanks
RE: SE custom templates gone?
If you can see those templates in file/new dialogbox, you have to do this:
1. in start-up screen, you see the section with standard templates
2. just belowt the template selection, you will see Edit Creation Option. Click on this link.
3. now click on Browse in new dialog box.
4. Select your template
5. now type the name of your template in Displayed name line and click on Add.
6. you can type something in Description, if you want.
7. Click on OK
That way you will add your templates to the start-up screen and ApplicationButton/New menu.
Hope, that this helps.
I might have to re-install SE?
Check the Solid Edge Options/File Location. There, you can set path for User Templates, if you have copied your templates to any other directory then the default one.
Puzzled?
Ken G.
http://grundey.blogspot.com
Have you checked out the Solid Edge Community site?
http://community.plm.automation.siemens.com/t5/Sol...
If I use exploer, go to my SE directory, I do find all the templates. I'm having to open, say my part template and then doing a SAVEAS to get started.
Ken G.
Thanks, I'll try your suggestion and let you know.
Thanks again!!
drew
C:\Program Files\Solid Edge ST_\Template old
C:\Program Files\Solid Edge ST_\Template2 new
Case conflit
