Transition duct, rectangular section to circular section
So I was trying to understand how fluid flow is affected through a transition duct when I found this study that was done. In the study it was noticed that there was a dramatic drop in velocity near the end of the transition near the edges and was also dependent on the length in the transition (Which makes sense). I was curious if anyone knew anything about the math behind this relationship to basically calculate the pressure drop and or velocity change based on the initial cross section, final cross section,and length of the transition (possibly even angle of transition and other things like that).
RE: Transition duct, rectangular section to circular section
Bring your wallet.
Mike Halloran
Pembroke Pines, FL, USA
Nominally, the same equations hold if the analysis is dimensionless, but practically? Do they work for design of real world parts with real world speeds and wall properties?
For 'wet' systems, where engine cooling water is injected to cool the piping, backpressure is much more difficult to calculate, but that's another discussion.
Mike Halloran
