NX Nastran- Solution Attribute : Stress Location - Center vs Corner
Recently i have shifted to Nastran solver from Model Solution.
When i was defining solution attributes , i came across an additional parameter called - "Stress location" in the case control tab. Under which four options like center,corner,SGAGE,cubic are found.
In my previous solver - i didn't found such parameter.
Is it necessary to consider this parameter?
Would it make a serious effect on my stress plot?
What kind of variation can i get if i give Center or corner or SGAGE as stress location.
Your comments will be really appreciated.
thanks.
RE: NX Nastran- Solution Attribute : Stress Location - Center vs Corner
Dear Ninjaz,
In NX AdvSim (the pre/post) and NX NASTRAN (the solver) you have the option to set how to comnpute and output element forces, stresses, and strains: at the centroid or at the corner grid points.
Then, to obtain the corner stresses in addition to the centroidal stress, you should request:
NX NASTRAN has the following Strain/Stress methods to recover results at corner points (check the NX NASTRAN manuals, everything is in the manuals!!) :
• SGAGE,
• CUBIC,
• CORNER and
• BILINEAR.
All the methods start by recovering strain at the element center and gauss points using the elemental strain matrix and the computed grid point displacements. From there, the various options control how these strains are extrapolated to corner locations for output. It is noted that stress results can be computed from strain using standard stress-strain relations. Thus the STRESS output control has the same recovery options as STRAIN. The explanation here describes the recovery for strain, but the analogy to stress is clear.
Except for the CENTER option which only returns strain at the center, all the other options return strain at the element center and corners. The strain at the center location is computed the same for all the options. The strain at corner locations is computed differently for the various corner options. BILINEAR uses a linear extrapolation method and is the more stable in most cases and is thus the default. The other corner options use higher order extrapolations in an attempt to be more accurate.
• BILINEAR – This is the default corner option and its usage is interchangeable with the CORNER option. This option uses the element linear interpolation functions to extrapolate the strain at the gauss points to the strain at the nodes. In the example of a linear varying moment in a cantilever modeled with CQUAD4 shell elements the strain variation across each element is constant. Across the length of the model, from the fixed point to the load application point, the strain will vary as a step function from element to element. This is because the CQUAD4 element has almost constant strain curvature, giving constant curvature at the gauss points, and when linear interpolated linearly yields constant strain over an element.
The discontinuity of strain from element to element can be minimized by refining the mesh. Nodal averaging of stress results, the default method in FEMAP postprocessor, will also smooth out the results.
• CUBIC – Is a corner option intended to smooth out the discontinuity of strain results between adjacent elements. Like the BILINEAR method it extrapolates strain to the corners using the element interpolation functions. Then it uses grid displacements and rotations to curve-fit a cubic equation that is used to adjust the linear corner strains. In the example of a linear varying moment in the cantilevered shell model, the grid point rotations will vary across the element so the curve fit gives the correct linear variation of strain curvature across the element, which translates to a linear varying stress. There is still some discontinuity of strain from element to element, but it is less than with the CORNER method.
Again, mesh refinement and nodal averaging can be used to minimize strain discontinuity.
• SGAGE – This method is similar to the CUBIC. But in-plane strains and curvatures are calculated independently for the cubic equation. First strains are calculated in the u and v and diagonal u-v directions at each grid point. The state of in-plane strain at the grid point is calculated using rosette strain gauge equations. Grid strain curvatures are done similarly. In the example of a linear varying moment in the cantilevered shell model, a non-constant strain variation is obtained across each element, however the accuracy is not as good as the CUBIC method. The SGAGE method is not recommended for most cases.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
