Why Does a Pressure Regulator's Consistency Vary Inversely w/ it's Setpoint?
In my research, most manufacturers seem to list a pressure regulator's accuracy in terms of a percentage of the target output pressure. So a pressure regulator with a 1% accuracy set to 100psi will only be +or- 1psi whereas the same regulator set to say 500psi (for illustrative purposes) will be +or- 5psi.
Ive studied up on the factors that contribute to regulator stability or instability (spring rate, sensing face area, cycling of the valve stem, etc.) but I cant figure out for the life me why the consistency would vary inversely with the output pressure.
RE: Why Does a Pressure Regulator's Consistency Vary Inversely w/ it's Setpoint?
Your mistake is in thinking the 100 psi and 500 psi regulators are the same. Accuracy is defined as a percentage of full scale not percentage of actual pressure.
