PCL for beginners
PCL for beginners
Hi every body
I am starting to learn PCL. I have found some simple examples for learning PCL in this link:
http://web.mscsoftware.com/support/online_ex/previ...
But I have a basic problem. What is PCL compiler. Where could I download a free PCL compiler to compile the codes?
Thank you
Thank you
RE: PCL for beginners
TTFN
It ssems I can use Matlab instead.
Thanks any way
May I ask You: do You know some links / books about PCL ? official manuals-pdf and www from MSC Company are only sources from which I can learn about PCL for Patran ?
best regards,
Mike.
"I contacted them, They talked me out of doing what I wanted to do with PCL!"
Amen to that... Looks like MSC is determined not to learn from its past mistakes...
