Calculate Incidence Angles to a Surface
I have a UG model of a nacelle that icing tests are being performed on. The surface temperature of the nacelle is being monitored by IR cameras. If the incidence angle at which the camera hits the surface of the nacelle exceeds a certain value (say 50 degrees) then the camera reading will be inaccurate. So I have been tasked to find the portions of the nacelle where the incidence angle with the IR camera are greater than 50 degrees.
The incidence angle is calculated by drawing a line from the camera center (known point) to some arbitrary point on the nacelle surface. From that point on the nacelle surface another line that is normal to the surface is drawn. The incidence angle is the angle between those two lines.
Now this is obviously a calculation I can do manually for a bunch of different points, but it becomes tedious very fast when attempting to isolate all surfaces that have an incidence angle greater than 50 degrees. So I was wondering if it is possible to do this in some sort of an automated fashion that would allow me to isolate/extract the surfaces that have an incidence angle greater than 50 degrees.
Thank you for your help!
RE: Calculate Incidence Angles to a Surface
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I thought of using Isocline curves too but that will not work in your case as you have to do the calculation based on the point source.
Best Regards
Kapil Sharma
Hope it helps.
Frank Swinkels
CODE -->
' Journal to get limit points Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Imports NXOpenUI Module incidentangle50 Dim s As Session = Session.GetSession() Dim ui As UI = ui.GetUI() Dim ufs As UFSession = UFSession.GetUFSession() Sub Main() Dim wp As Part = s.Parts.Work PointStart: ' select a point Dim pnt1 As Point = Nothing Dim response1 As Selection.Response = Selection.Response.Cancel response1 = select_a_Point(pnt1) If response1 = Selection.Response.Back Then GoTo End1 If response1 = Selection.Response.Cancel Then GoTo End1 Dim coordpnt() As Double = {pnt1.Coordinates.X, pnt1.Coordinates.Y, pnt1.Coordinates.Z} FaceStart: Dim face1 As Face = Nothing Dim message1 As String = "Select a face" Dim response2 As Selection.Response = Selection.Response.Cancel response2 = select_a_Face(message1, face1) If response2 = Selection.Response.Back Then GoTo PointStart If response2 = Selection.Response.Cancel Then GoTo End1 Dim response3 As Selection.Response = Selection.Response.Cancel ' get limit points for constant u and constant v ' first get the normal point Dim parm0(1) As Double Dim pt0(2) As Double Dim pt1(2) As Double Dim pt2(2) As Double Dim pt3(2) As Double Dim parm1(1) As Double Dim parm2(1) As Double Dim parm3(1) As Double Dim ptlimit1(2) As Double Dim vec1(2) As Double Dim cross1(2) As Double Dim angle1 As Double = Nothing Dim junk3(2) As Double Dim norm1(2) As Double Dim junk2(1) As Double Dim u0 As Double = Nothing Dim u1 As Double = Nothing Dim u2 As Double = Nothing Dim v0 As Double = Nothing Dim v1 As Double = Nothing Dim v2 As Double = Nothing Dim v3 As Double = Nothing Dim n0(2) As Double Dim n1(2) As Double Dim n2(2) As Double Dim n3(2) As Double Dim temptag As Tag = Tag.Null Dim foundlimitpoint As Boolean = False Dim uvminmax(3) As Double ufs.Modl.AskFaceUvMinmax(face1.Tag, uvminmax) ' point1 ufs.Modl.AskFaceParm(face1.Tag, coordpnt, parm0, pt0) parm1(0) = uvminmax(0) parm1(1) = parm0(1) ufs.Modl.AskFaceProps(face1.Tag, parm1, pt1, junk3, junk3, junk3, junk3, n1, junk2) ufs.Vec3.Sub(coordpnt, pt1, vec1) ufs.Vec3.Cross(vec1, n1, cross1) ufs.Vec3.AngleBetween(vec1, n1, cross1, angle1) angle1 = convertRadianToDegree(angle1) If angle1 > 50.0 Then ufs.Modl.AskFaceParm(face1.Tag, coordpnt, parm0, pt0) foundlimitpoint = getLimitPoint(face1, coordpnt, pt0, pt1, parm0, parm1, pt3, angle1) If foundlimitpoint = True Then ufs.Curve.CreatePoint(pt3, temptag) End If End If ' point2 ufs.Modl.AskFaceParm(face1.Tag, coordpnt, parm0, pt0) parm1(0) = uvminmax(1) parm1(1) = parm0(1) ufs.Modl.AskFaceProps(face1.Tag, parm1, pt1, junk3, junk3, junk3, junk3, n1, junk2) ufs.Vec3.Sub(coordpnt, pt1, vec1) ufs.Vec3.Cross(vec1, n1, cross1) ufs.Vec3.AngleBetween(vec1, n1, cross1, angle1) angle1 = convertRadianToDegree(angle1) If angle1 > 50.0 Then foundlimitpoint = getLimitPoint(face1, coordpnt, pt0, pt1, parm0, parm1, pt3, angle1) If foundlimitpoint = True Then ufs.Curve.CreatePoint(pt3, temptag) End If End If ' point3 ufs.Modl.AskFaceParm(face1.Tag, coordpnt, parm0, pt0) parm1(0) = parm0(0) parm1(1) = uvminmax(2) ufs.Modl.AskFaceProps(face1.Tag, parm1, pt1, junk3, junk3, junk3, junk3, n1, junk2) ufs.Vec3.Sub(coordpnt, pt1, vec1) ufs.Vec3.Cross(vec1, n1, cross1) ufs.Vec3.AngleBetween(vec1, n1, cross1, angle1) angle1 = convertRadianToDegree(angle1) If angle1 > 50.0 Then foundlimitpoint = getLimitPoint(face1, coordpnt, pt0, pt1, parm0, parm1, pt3, angle1) If foundlimitpoint = True Then ufs.Curve.CreatePoint(pt3, temptag) End If End If ' point4 ufs.Modl.AskFaceParm(face1.Tag, coordpnt, parm0, pt0) parm1(0) = parm0(0) parm1(1) = uvminmax(3) ufs.Modl.AskFaceProps(face1.Tag, parm1, pt1, junk3, junk3, junk3, junk3, n1, junk2) ufs.Vec3.Sub(coordpnt, pt1, vec1) ufs.Vec3.Cross(vec1, n1, cross1) ufs.Vec3.AngleBetween(vec1, n1, cross1, angle1) angle1 = convertRadianToDegree(angle1) If angle1 > 50.0 Then foundlimitpoint = getLimitPoint(face1, coordpnt, pt0, pt1, parm0, parm1, pt3, angle1) If foundlimitpoint = True Then ufs.Curve.CreatePoint(pt3, temptag) End If End If ' point5 ufs.Modl.AskFaceParm(face1.Tag, coordpnt, parm0, pt0) parm1(0) = uvminmax(0) parm1(1) = uvminmax(2) ufs.Modl.AskFaceProps(face1.Tag, parm1, pt1, junk3, junk3, junk3, junk3, n1, junk2) ufs.Vec3.Sub(coordpnt, pt1, vec1) ufs.Vec3.Cross(vec1, n1, cross1) ufs.Vec3.AngleBetween(vec1, n1, cross1, angle1) angle1 = convertRadianToDegree(angle1) If angle1 > 50.0 Then ufs.Modl.AskFaceParm(face1.Tag, coordpnt, parm0, pt0) foundlimitpoint = getLimitPoint(face1, coordpnt, pt0, pt1, parm0, parm1, pt3, angle1) If foundlimitpoint = True Then ufs.Curve.CreatePoint(pt3, temptag) End If End If ' point6 ufs.Modl.AskFaceParm(face1.Tag, coordpnt, parm0, pt0) parm1(0) = uvminmax(1) parm1(1) = uvminmax(2) ufs.Modl.AskFaceProps(face1.Tag, parm1, pt1, junk3, junk3, junk3, junk3, n1, junk2) ufs.Vec3.Sub(coordpnt, pt1, vec1) ufs.Vec3.Cross(vec1, n1, cross1) ufs.Vec3.AngleBetween(vec1, n1, cross1, angle1) angle1 = convertRadianToDegree(angle1) If angle1 > 50.0 Then foundlimitpoint = getLimitPoint(face1, coordpnt, pt0, pt1, parm0, parm1, pt3, angle1) If foundlimitpoint = True Then ufs.Curve.CreatePoint(pt3, temptag) End If End If ' point7 ufs.Modl.AskFaceParm(face1.Tag, coordpnt, parm0, pt0) parm1(0) = uvminmax(0) parm1(1) = uvminmax(3) ufs.Modl.AskFaceProps(face1.Tag, parm1, pt1, junk3, junk3, junk3, junk3, n1, junk2) ufs.Vec3.Sub(coordpnt, pt1, vec1) ufs.Vec3.Cross(vec1, n1, cross1) ufs.Vec3.AngleBetween(vec1, n1, cross1, angle1) angle1 = convertRadianToDegree(angle1) If angle1 > 50.0 Then foundlimitpoint = getLimitPoint(face1, coordpnt, pt0, pt1, parm0, parm1, pt3, angle1) If foundlimitpoint = True Then ufs.Curve.CreatePoint(pt3, temptag) End If End If ' point8 ufs.Modl.AskFaceParm(face1.Tag, coordpnt, parm0, pt0) parm1(0) = uvminmax(1) parm1(1) = uvminmax(3) ufs.Modl.AskFaceProps(face1.Tag, parm1, pt1, junk3, junk3, junk3, junk3, n1, junk2) ufs.Vec3.Sub(coordpnt, pt1, vec1) ufs.Vec3.Cross(vec1, n1, cross1) ufs.Vec3.AngleBetween(vec1, n1, cross1, angle1) angle1 = convertRadianToDegree(angle1) If angle1 > 50.0 Then foundlimitpoint = getLimitPoint(face1, coordpnt, pt0, pt1, parm0, parm1, pt3, angle1) If foundlimitpoint = True Then ufs.Curve.CreatePoint(pt3, temptag) End If End If End1: End Sub Public Function getLimitPoint(ByVal face1 As Face, ByVal p0() As Double, ByVal p1() As Double, ByVal p2() As Double, ByVal parm1() As Double, _ ByVal parm2() As Double, ByRef p3() As Double, ByRef a3 As Double) As Boolean Dim junk3(2) As Double Dim norm1(2) As Double Dim junk2(1) As Double Dim aimangle As Double = 50.0 * Math.PI / 180.0 Dim checkcount As Integer = 0 Dim tol1 As Double = 0.0001 Dim n3(2) As Double Dim vec1(2) As Double Dim delangle As Double = Nothing Dim parm3() As Double = {(parm1(0) + parm1(0)) / 2.0, (parm1(1) + parm1(1)) / 2.0} Dim cross1(2) As Double ufs.Modl.AskFaceProps(face1.Tag, parm2, p3, junk3, junk3, junk3, junk3, n3, junk2) ufs.Vec3.Sub(p0, p3, vec1) ufs.Vec3.Cross(vec1, n3, cross1) ufs.Vec3.AngleBetween(vec1, n3, cross1, a3) If a3 < aimangle Then Return False End If delangle = Math.Abs(a3 - aimangle) While delangle > tol1 If a3 > aimangle Then ufs.Vec3.Copy(p3, p2) ufs.Modl.AskFaceParm(face1.Tag, p1, parm1, p1) ufs.Modl.AskFaceParm(face1.Tag, p2, parm2, p2) Else ufs.Vec3.Copy(p3, p1) ufs.Modl.AskFaceParm(face1.Tag, p1, parm1, p1) ufs.Modl.AskFaceParm(face1.Tag, p2, parm2, p2) End If parm3(0) = (parm1(0) + parm2(0)) / 2.0 parm3(1) = (parm1(1) + parm2(1)) / 2.0 ufs.Modl.AskFaceProps(face1.Tag, parm3, p3, junk3, junk3, junk3, junk3, n3, junk2) ufs.Vec3.Sub(p0, p3, vec1) ufs.Vec3.Cross(vec1, n3, cross1) ufs.Vec3.AngleBetween(vec1, n3, cross1, a3) checkcount += 1 If checkcount > 20 Then Return False End If delangle = Math.Abs(a3 - aimangle) End While Return True End Function Public Function convertRadianToDegree(ByVal angleRadians As Double) As Double Dim angledegrees As Double = angleRadians * 180.0 / Math.PI Return angledegrees End Function Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image immediately after execution within NX GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately End Function Function select_a_Point(ByRef pnt1 As Point) As Selection.Response Dim mask(0) As Selection.MaskTriple With mask(0) .Type = UFConstants.UF_point_type .Subtype = 0 .SolidBodySubtype = 0 End With Dim cursor As Point3d = Nothing Dim resp As Selection.Response = _ ui.SelectionManager.SelectObject("Select point to project from", "Select a Point", _ Selection.SelectionScope.AnyInAssembly, _ Selection.SelectionAction.ClearAndEnableSpecific, _ False, False, mask, pnt1, cursor) If resp = Selection.Response.ObjectSelected Or _ resp = Selection.Response.ObjectSelectedByName Then Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function Function select_a_Face(ByVal message As String, ByRef obj As Face) As Selection.Response Dim selectionMask_array(0) As Selection.MaskTriple With selectionMask_array(0) .Type = UFConstants.UF_face_type .Subtype = 0 .SolidBodySubtype = 0 End With Dim cursor As Point3d = Nothing Dim resp As Selection.Response = _ ui.SelectionManager.SelectObject("Face Selection", message, _ Selection.SelectionScope.AnyInAssembly, _ Selection.SelectionAction.ClearAndEnableSpecific, _ False, False, selectionMask_array, obj, cursor) If resp = Selection.Response.ObjectSelected Or _ resp = Selection.Response.ObjectSelectedByName Then Return Selection.Response.Ok ElseIf resp = Selection.Response.Back Then Return Selection.Response.Back Else Return Selection.Response.Cancel End If End Function End ModuleRE: Calculate Incidence Angles to a Surface
