Wrap along Cylinder face
Hi All
Anyone can help / suggest me How to wrap a solid part along cylinder face in UGNX 7.5 or UGNX 8.5
I have a Spoon part which is to be created on a cylinder.
I attached a Screen shot.
Thanking you.
RE: Wrap along Cylinder face
Is that what you WANT it to look like? If not, please give us some idea what it is the you're looking for.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
As of now i can see Global Shaping (you can try metaform also but since the spoon you have shown in the image is almost wraping almost one third of the cylinder so i am not sure what result will it yield )as the only option to achieve this but in that case also if you require the core and cavity side then it wont be a single step process.
Best Regards
Kapil
Hi John,
Please have a look on attached picture , you will get full idea,
Here is Im giving some hint about wrap a solid on cylinder, I used Global Shape. But I don't know How to control size of dia.
For Eg. Sppon Total Length is 80 mm
cylinder Dia is 60mm
If you dont mind, could you Please can you prepare a sample part for us .
Thanking you
