Anchor Rod to Vertical Dowel Spacing
Is there a code required minimum spacing between an anchor rod and a vertical dowel?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Anchor Rod to Vertical Dowel Spacing
If they are to be used additive for shear or tension, I would follow the above recommendation and treat it as a separate rebar and follow those spacing requirements so as to not have a local overstress in your concrete or masonry.
The rebar may have adequate length away from the headed stud / anchor rod so as to not need any development in the region where they touch. In that case, it would be ok.
Don't confuse this with lapping, it's not lapping. You are developing the pier reinforcement above the failure plane of the breakout cone.
