Effective edition EN 13480
Hopefully someone can answer this. I was wondering how to determine the effective edition of the EN 13480 design code.
I noticed issue 2 (sept 2013) just came out, (already) incl. some amendments (EN 13480-2:2012/A1, EN 13480-4:2012/A1 and EN 134805:2012/A1).
Other piping codes like B31.3 simply (but effectively!) state that when a code becomes effective (e.g. 6mo after the 'Date of Issuance'), it's not to used retroactive, and that the latest edt (effective before contract sign date) determines the applicable edt.
Q1) How to determine the applicable edition of EN 13480 for a project, when the contract is signed dd-mm-yyyy?
Q2) What to do when during a project a new edition comes, or amendments are issued? I assume you have to stick to the edition thats being used, but EN 13480 doesnt explicitly spell out anything out on this.
RE: Effective edition EN 13480
one sample :
NEN-EN 287-1:2011
At the end of its period of validity, the existing and valid qualification testing of welders in accordance with the
requirement of the previous edition of this standard may be revalidated according to the previous edition.
Alternatively, the range of qualification may be updated in accordance with this edition. All new qualifications
and re-qualifications shall be in accordance with this edition
Amendments/the corrigenda which have been approved previously by CEN members, the corrected pages up
to Issue 17 without any further technical change. Annex Y provides details of significant technical changes
between this European Standard and the previous edition.
Amendments to this new edition may be issued from time to time and then used immediately as alternatives to
rules contained herein. It is intended to deliver a new Issue of EN 13480:2012 each year, consolidating these
Amendments and including other identified corrections.
Guess the question is that hard to answer.
OSIRIS7 had the best proposed solution I think ...
