How to remove the "Finding your way around NX" startup information?
I know it asks you if you want to remove the "Finding your way around NX" after 30 or so open sessions of NX. But I recently installed it on another computer an I was so used to the blueish background.
It's a stupid question, and probably after some time it will go away, but is there a way to do it before the 30 or so sessions?
Thanks!
Alex H
Thanks!
Alex H
RE: How to remove the "Finding your way around NX" startup information?
One approach is to change the Windows registry using the NX command window with the following single-line command:
CODE -->
This example is for NX 8.5, change the 8.5 accordingly if you are using a different NX Major.Minor version. E.g. 7.5
Hope this is helpful,
Joe
Alex,
Thanks for the feedback. It should have been /f not /y
CODE -->
Tim Banks
Application Engineer
VMH International
NX 8.5 / Solid Edge ST6
