Catia V5 - Adjust "Measure" font size in 3D - Admin Mode?
Hello I have been searching and can't seem to figure this one out. When you're in 3D (GSD or Part Design) and do a "Measure Between" how can I increase the font size of the result? In properties I can only change the colors, I figured it was somewhere in Tools--Standards when in Admin mode.
Any ideas would be appreciated. I have attached a screenshot for an example.
FYI Currently using Catia V5r18
RE: Catia V5 - Adjust "Measure" font size in 3D - Admin Mode?
I don't think you can change that (ADMIN mode or not). Maybe if you change your windows font?
Same question was asked several years ago: http://eng-tips.com/viewthread.cfm?qid=196911
Ah Ok thanks for the response. We have a customer that can't read them easily so I've basically been saving it, opening it in paint, and adding bigger text.
