Applicable of Radius of Gyration
For a single angle in tension with bolted connection in horiZontal leg, you have yielding tensile strength controlling. How would you explain to select rz over other radii of gyration while calculating slenderness ratio.
Is there a way to remember which radius of gyration to select among all provided values?
RE: Applicable of Radius of Gyration
But, if you're designing to any kind of a code (AISC, for example), you use the value specified in that code, and that value can vary.
http://www.nceng.com.au/
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning."
