Explain definition please UW-16(f)(3)(a)(2)
Could anyone please give me some explanation of the wording of UW-16(f)(3)(a)(2)
which says:
"(2) the maximum size of the opening in the vessel is limited to the outside diameter of the attached pipe
plus 3⁄4 in. (19 mm), but not greater than one-half of the vessel inside diameter"
In what case would a fitting have an opening which is 19 mm greater than the outside diameter?
RE: Explain definition please UW-16(f)(3)(a)(2)
That limitation is just a maximum, and, for a 3" threaded insert, I guess the limit could be easily attained.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
Thanks Prex
