Problem with a face
Problem with a face
I've faced a problem which I can't handle. I have an old design in which there is a face that has an intersection that isn't perfect. When milling this part we get a small "bump" of five microns which isn't wanted.
So my question is if there is any way to change the intersection on this face, which I believe will solve the problem.
When generating the CAM NC on this part the problem gets more visible, unfortunately I do not have an image of that at this moment.
I am using NX 6.0.5.3
RE: Problem with a face
2) can you extract, export and upload the faces visible in the picture ? ( only these 4-5 faces should not reveal any company secrets.)
Tomas
